PhreQQ
tldr; can you help identify if these axles are OEM?
Hello excellent TDIers, I recently bought another TDI, a 03 02m jetta with about 250k, and within the first tank the rack and pinion blew a inner rod seal something fierce. So I am in the middle of that replacement (along with a full suspension refresh, I think it was on original everything ) and noticed how messed up my inner cv axle boots are. He said the boots were a little torn but no issues. Looks like PO tried to zip tie plastic bags over the boots ...
The driver side is definitely smaller diameter and solid, while the passenger side is hollow. I first thought that must mean some cheap Chinese replacements went in at some point on at least one of the sides, but after searching around it sounds like that was actually by design to help with torque steering, neat. Is there any identifying marks or design that could help me identify if these are OE and I should consider replacing the cv joints instead of shelling out $700 for replacement new oem axles?
