Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old August 30th, 2011, 14:07   #1666
Thunderstruck
Thunderstruck's Avatar
A no additives clause from VW would imply you must use untreated fuel. If the terminal puts additive in, there goes the warranty.
Thunderstruck is offline   Reply With Quote
Old August 30th, 2011, 14:09   #1667
Derrel H Green
Derrel H Green's Avatar
Fuel Economy: Check my Fuelly
Arrow Suggestions
Originally Posted by Softrockrenegade View Post
Derrel, thanks for the recommendation! When you say you add a liter of bio,
is that B100 or a lower blend?
And also in my owners manual, it recomends no additives.
Will using one such as your recommendation void the factory warrenty? [No!]
Thanks, Ryan
You are most welcome.
All comments be everyone above are good, and are to be taken seriously!
I use one (1) liter of B99 (Biodiesel available from Downs, a local fuel distributor
in Corona CA about 32 miles away from where I live in Murrieta.
Besides their B99 pump, they also have two other pumps, B10 and B20.
I have a good friend who is regularly pumping full tanks of B10 and his sedan is running
rather well to be sure. He says that Indiana is mxing their D2 to produce B11 at
all stations.
Study that Spicer report and draw your own conclusions.
But be sure to use some additive, any additive for good insurance.
Try Opti-Lube XPD and see if your mileage doesn't improve just a little bit,
and see if you don't think your motor runs better and smoother?
In your area, you'll most likely have to send away for Opti-Lube.
D
2010 JSW. Reflex Silver/Titan Interior. A TDI with DSG.
Dynoed 132 HP, 230 ft/lb torque at the wheels.
Traded the VW for a Mercedes Benz W-211 E-320 CDI 12-17-2011.
Dynoed 12-01-12 211 HP, 386 ft/lb torque at the wheels.
View my MBZ E-320 CDI Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320
Compare our previous VW TDI JSW DSG Fuelly : http://www.fuelly.com/driver/derrelhgreen/Jetta
Derrel H Green is offline   Reply With Quote
Old August 30th, 2011, 14:10   #1668
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Somewhere back in this thread was an additive supplier that listed a VW TSB stating that they had an improved additve. Perhaps if I have time, I'll find it.
Found it - Stanadyne lists this:
VW Service bulletin recommendation.
VW p/n ZVW 340 001 is SAC 32938
Lubricity Formula
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old August 30th, 2011, 15:43   #1669
ZiggyTheHamster
ZiggyTheHamster's Avatar
Lubricity Formula
Applies only to PDs. I think.
Thanks for the reassurance I'm loving it soo far !!!
Your poor front bumper! Now it's got four holes in it!
2009 VW Jetta TDI - Black w/ DSG Born: 5/2009
DSG Paddle Shift Steering Wheel
RCD-510 Stereo
9W2 Bluetooth
ZiggyTheHamster is offline   Reply With Quote
Old August 30th, 2011, 16:16   #1670
Softrockrenegade
Softrockrenegade's Avatar
Damn New Jersey and our stupid front plates !!!
Softrockrenegade is offline   Reply With Quote
Old August 30th, 2011, 16:47   #1671
oxford_guy
TDI(s): Golf '11
It's easy enough to write it so that it only applies to additives added by users, rather than additives in fuel from pumps. If it exists in reality, it can be written in.
How can they tell? I don't know, but it may be possible in certain circumstances. For instance, they may not be able to tell if it's user-added bio, but it may be possible if it's PS or Opti.
FSF: Fuel System Failure. "Since the CR fuel system failure is so expensive, ... " eddif
oxford_guy is offline   Reply With Quote
Old August 30th, 2011, 18:22   #1672
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Any fuel additive is considered an additive only when it is added after the fuel is sold at retail.
If it was added before the retail sale it is just part of the fuel we purchased as far as any of us can be concerned.
Come back to reality, folks. THINK.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old August 30th, 2011, 19:12   #1673
kjclow
You're probably right but I haven't been able to find anyone that has a copy of it. I guess I can ask the dealer when I pick up my new TDI this next week Then I'll have two in the garage.
Old August 30th, 2011, 19:38   #1674
El Dobro
El Dobro's Avatar
TDI(s): 2014 Volt
Fuel Economy: 115 MPGe
The Stanadyne Lubricity Formula is for any diesel. GM also recommends it.
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
"He's opening our minds to new ideas, KILL HIM!!!" -Futurama
Now, I drive more, worry less.
Penguin -The other white meat.
El Dobro is offline   Reply With Quote
Old August 31st, 2011, 04:14   #1675
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
Right, but the TSB is only for PDs and older, I believe. That is, VW recommends it for VEs and PDs, but not CRs.
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is offline   Reply With Quote
Old August 31st, 2011, 08:40   #1676
El Dobro
El Dobro's Avatar
TDI(s): 2014 Volt
And we all know VW can go flick themselves regarding the use of lubricity additives with the CR engines.
Old August 31st, 2011, 09:52   #1677
mxs
I think if more people understood the difference between diesel fuels sold in Canada vs US, less people would be just blaming VW for HPFP failures. They designed the car expecting certain level of fuel. Seeing how people from different states write about non-existing policies or measures to guarantee a quality of diesel makes me think ....
Having said that, one question mark is why would VW sold a diesel car in a region where a required clean enough fuel is not readily available (I presume they knew it ...)? One way to deal with it would be using more robust/expensive pump which could take dirtier fuel without significantly changing pump lifespan expectancy.... Maybe they knew it, but someone was trying to save a dollar or two ... in the short term. Sounds like hard to believe logic, but who knows anything is possible nowadays.
Is there any other diesel car sold in US which runs the same pump. I believe there's only one or two HPFP pump manufacturers in the whole world (Bosch is one ...). Should not be that hard to crack ...
mxs is offline   Reply With Quote
Old August 31st, 2011, 10:05   #1678
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
That point about VW not designing a product fit for purpose has been brought up many, many times.
In any case, as far as pumps go, the only vehicles in the US using the Bosch CP4 family pumps are:
VW Golf/Jetta/Audi A3 2.0 TDI
VW Touareg/Audi Q7 3.0 TDI
Ford F-250/350 6.7 PowerStroke
2011 Chevy Silverado/Express/GMC Sierra/Savana Duramax
AFAICT, they're not blowing up in Ford or GM applications.
Old September 1st, 2011, 16:18   #1679
madmako
madmako's Avatar
Fuel Economy: +50 mpg hwy
Default Verrry Interesting....
"....they're not blowing up in Ford or GM applications."
If this is true, this puts a whole new spin on things, I would imagine.
Does Not Suffer Fools Gladly
madmako is offline   Reply With Quote
Old September 1st, 2011, 18:21   #1680
El Dobro
El Dobro's Avatar
TDI(s): 2014 Volt
The HPFP seems to be fine in the CR M-B diesels, too.
HPFP Failure in V6 TDI, or only in 2.0 CR? Trooper81 Fuels & Lubricants 65 May 30th, 2014 18:52
CR High Pressure Fuel Pump "HPFP" failure FAQ - Updated 2/8/2011 dzcad90 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 June 28th, 2010 13:52
Good Job! NHTSA investigation candywhite VW MKV-A5 Golf/Jettas 15 July 28th, 2009 02:26
NHTSA opens investigation on DSG transmisisons dieselyeti VW MKV-A5 Golf/Jettas 1 July 24th, 2009 11:07
Page generated in 0.25479 seconds with 11 queries
[Output: 140.94 Kb. compressed to 118.52 Kb. by saving 22.42 Kb. (15.91%)]
