Old July 21st, 2009, 04:52   #1
candywhite
TDI(s): 09jsw
Default Good Job! NHTSA investigation
Kudos to all of you who did not just decide to accept VW's arrogance.
Now to hope that a real investigation of the extent and prevalence of the problem happens.
candywhite is offline   Reply With Quote
Old July 21st, 2009, 08:17   #2
tdiatlast
"Component: POWER TRAIN:MANUAL TRANSMISSION"
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2014 Cadillac ELR, purchased 3/18
tdiatlast is online now   Reply With Quote
Old July 21st, 2009, 08:19   #3
Lightflyer1
Lightflyer1's Avatar
It is a computer controlled manual transmission after all.
Old July 21st, 2009, 10:39   #4
ErikR
Fuel Economy: 590 miles /tank so far
Can you guys fill me in a bit more, did I miss a post? Sounds like the board is looking into the premature manual trans clutch failures in A5's. I'd give a 0% chance of getting reimbursed from VW, but again I'm just looking for some more info...
ErikR is offline   Reply With Quote
Old July 21st, 2009, 10:57   #5
ajlockfeld
ajlockfeld's Avatar
Glad to see that an investigation was opened. Now VW has to respond. It is peculiar that it is described as a manual transmission. All the complaints (including mine) were filed as automatic transmission. Either NHTSA decided it is really a manual or somebody goofed.
I sent an email to VW customer CARE and got back a response allegedly from a real person (some of it sounded like automatically generated responses) although he didn't seem to understand the problem. The response claims that VWoA monitors 3rd party internet discussion sites (such as this one?) to get a handle on emerging problems. They seem kind of behind the curve on this one.....
Alex from Eugene
09 JSW, DSG, Pano, Silver/Anthracite
2015 eGolf Electric Blue
ajlockfeld is offline   Reply With Quote
Old July 21st, 2009, 16:23   #6
DoctorDawg
DoctorDawg's Avatar
Your tax dollars at work (for a change).
2009 Jetta TDI (Loyal Edition, Campi White, DSG, #1470, built 5/08): 56K miles and zero problems 1/16/2011.
WeatherTech deflectors, Dieselgeek skid plate (both A+)
My other diesel gets 120 MPG (minutes per gallon): Kubota 2630 w/ FEL
My other other diesel I don't even want to talk about (1995 Dodge Ram 2500 Cummins 4x4)
DoctorDawg is offline   Reply With Quote
Old July 21st, 2009, 16:58   #7
ErikR
Ok I see the attachment now. Still don't think this has a chance in hell to amount to anything.
Old July 21st, 2009, 19:02   #8
candywhite
TDI(s): 09jsw
Hopefully it won't and it was just an isolated run of bad sensors or installations. But this will make it more difficult for VW to avoid responsibility and may make it easier on those of us who have had to deal with VW service.
This is also how recalls begin and could save a life in the future. Even one will amount to a whole lot. It may prevent the experience some of us have had on the road which I would not wish on anyone.
Old July 21st, 2009, 19:17   #9
Lightflyer1
Maybe they will investigate the dmf while they are in there.
Old July 21st, 2009, 19:58   #10
Turbine Suburban
What does dmf stand for?
Turbine Suburban is offline   Reply With Quote
Old July 21st, 2009, 20:03   #11
Lightflyer1
dual mass flywheel. Been known to disintegrate and take out the tranny.
Old July 21st, 2009, 20:14   #12
Turbine Suburban
Ahhh. I knew that.(knocks head) Hope that got that figured out for the 09's!
Old July 24th, 2009, 18:54   #13
El Dobro
El Dobro's Avatar
Fuel Economy: 115 MPGe
I see that there were 15 complaints about the rough shifts, so I'll be adding one more to that number.
El Dobro is online now   Reply With Quote
Old July 25th, 2009, 10:21   #14
Azone
Excellent. We only had this problem once, and that's when we were getting out of the parking lot, and when in drive, the car was in neutral. Hasn't happened since, but if it does, this is good.
Azone
2009 Volkswagen Jetta TDI Sedan - Red, Anthracite, DSG, Sunroof
Azone is offline   Reply With Quote
Old July 25th, 2009, 22:27   #15
Anomie
TDI(s): 09 Jetta DSG
Originally Posted by El Dobro
I see that were 15 complaints about the rough shifts, so I'll be adding one more to that number.
I was trying to be optimistic about the rough downshifts when coming to a stop, but after driving a friend's 08/09 Audi A3 with DSG, I'm really starting to take note that this is an unacceptable amount of lurch. I think I'll add to this list.
Where's that link again...?
Anomie is offline   Reply With Quote
Page generated in 0.16341 seconds with 10 queries
[Output: 116.77 Kb. compressed to 95.92 Kb. by saving 20.85 Kb. (17.86%)]
