I recently came to my 2000 Jetta TDI MK4 and it wouldn't start. I looked under the hood and there was no fuel in the intake fuel lines. I replaced them and it after priming it still wouldn't start. I finally saw where it was leaking from, it was leaking from past the injector in the return hose. I replaced that and it starts fine now, though recently it looked under there and it's still leaking, but not from the hose now, it's leaking from the injector itself. At the base. It's a little lose I believe. When I move it from side to side I can see the fuel move slightly. My question is, do you think it's the seals? Or do I just need to tighten it up? I thought I'd see what you all thought before doing anything rash. I know something needs to happen but not sure if it really needs to be taken apart of not. Thanks! Peter
