bassman5066
- Joined
- Apr 8, 2011
- Location
- Honey Brook PA
- TDI
- 2011 Golf 2 Door TDI (sold back for Dieselgate), 91 Golf 4 Door with 1Z swap
Sorry about the wide pics. I tried to resize them when I posted but the forum tool to do that doesn't seem to work.Thanks
Yeah I see now, the images made the page so wide that I couldn't see on my screen, lol.
If you log group 04, you can see timing req, timing actual, and n18 duty cycle. If they don't match and the n18 duty cycle is way high, that means the pump is either losing pressure, static timing too low, or the case relief valve might have a problem.
Also interested to see what you get at higher rpm. Even without load is a good test with the pressure/vac gauge because the IP vane pump flow is directly related to RPM, not fueling. Internal pressure is regulated by the case relief valve.
I did manage to record some logs before the laptop died. I'll post them once I get off work today. I logged start of injection (specified and actual), throttle position, boost, fuel consumption, fuel temp. One interesting thing I did notice was the highest number logged for fuel consumption was 25l/hr, which is still only 6.6 gallons (my lift pump is rated for 45 gph). That was at 100% throttle going uphill in 4th. So even if the vane pump outpaces my lift pump(that would yield a vacuum reading on my fuel feed lines with the lift pump on), I am still getting plenty enough fuel into the motor. I did decide to remove the oil pressure shut off and just run the pump on key on, because in low rpm situations (parking lots and such) I could hear the relay clicking on and off a little quick for my liking. I dont want to kill the relay with too many on off cycles.
One key thing to remember here is that pressure can only be made with a restriction, not a pump. All the pump does is displaces a fluid. In most cases (gasser efi setups) that restriction is the fuel pressure regulator. The regulator is what allows the pump to build pressure in the first place. So, with any fuel pump, whether its a lift pump, efi fuel pump, or even the HPFP on my 2011 CR, if you were to run it without some sort of regulator or restriction, its still not going to build pressure at the outlet.
So that begs the question, what is really causing my system to build pressure in the first place? The filter, and the IP are the regulators in our case. Does the vane pump in our IP allow for flow through? If it does not, fuel may just be flowing right across the filter and back out the return and that is whats allowing it to build pressure. I would like to tee my pressure gauge in AFTER the filters next time and see what I read there, because there will be a drop across the filters, and even though I didn't see a vacuum BEFORE the filters, I may see one after.
Either way though, the way I look at it, as long as my system holds some positive pressure under the highest fuel demand, my lift pump has a high enough flow rating to work with my setup. If at any point during high fuel demand, my system goes to a vacuum, that would completely defeat the purpose of having a lift pump, because that would show the pump cannot keep up in the exact situation I need it most. I am also thinking about adding a flow meter to see what ACTUAL flow is rather than running all my numbers off of rated flow.
Sent from my Bosch ECU via VAG COM
