sdeck
- Joined
- Aug 25, 2006
- Location
- Northern Colorado Front Range
- TDI
- 2003 Jetta, 253K, 01M, DLC520s, VNT-17(sold); 2014 Passat SE 6M, 61,000 miles (Feb 16 buyback date)
I had my 01M flushed at an independent VW/MB shop at 100K. They did not change the filter. Now at 155K, I am "flushing" my 01M myself with multiple changes. My drain amounts seem low compared to the 3.0 or so most folks quote. Unfortunately, when I drained it cold the first time, I had the front up on ramps, so the drip method was invalid. Fluid looked fine, a bit dark, but still plenty red. magnet had some very fine black "goop" on it, but nothing I would consider excessive. No chunks or pieces.
I dropped the pan (cold) and got 2.3 L total out. new filter, filled w/ 2.3 L
drove 10 miles, drained hot. 0.65L with tube in, 0.7L after removing tube, 0.8L after 3 hours of dripping/draining (2.15L total). filled w/ 2.15L
drove 10 miles, 0.6L w/ tube in, 0.75 with plug removed, 1.0L overnight drain/drip. filled w/ 2.35L
drove 10 miles. draining for fourth time right now.
Any thoughts on this "low" drainage volume?
