Last summer the 2006 Jetta MKV was hesitating in upper RPM's and here's the reason why. Jeff from Rocket Chip found it to be a bad fuel filtre which was clogging supply... This was due to bad fuel.
One year later...almost to the exact date while driving upper state NY we had the same issues... but this time I had a new fuel filtre in the trunk and my tools.
As you can see... it's oil
Not as bad as last year but this was the very first sign of hesitation in the upper RPMs. The first time this happened we drove a few months before getting it changed. [At that time we didn't know it was a filtre issue... this year we knew immediately]
A few trips on the on-off ramps in upper state after changing the filtre cleaned out the residue.
