My 2005 Jetta has the MIL light on for the turbocharger sensor failure P2564. In the past I have cleared the code with OBDWiz and it has stayed off for some variable period of time only to return. Today I tried to clear the code and it stayed off however reappeared after I turned the car on and off. I will experiment with this over the next few days, however my question is this:
On the "monitor" section of OBDWiz I show 5 elements that are listed as "not available." They are:
Catalyst
Heated Catalyst
Evap System
Secondary Air System
AC Refrigerant
Everything else shows available. All of the items show as incomplete and on the bottom of the screen the program does tell me there are 0 error codes however the car is not ready for emissions testing.
I know there is some sort of cycle as to making the car ready for emissions testing but everything I have googled has been inconclusive to 500 miles since you reset the MIL to 15 minutes. Does anyone know the exact parameters that make the car ready for emissions testing? Is my case a hopeless lost cause for now? The only quote I was given on fixing my MIL error was approximately $2000 to remove and replace the entire turbocharger unit with a new or re manufactured turbo charger. I'm also up for suggestions on how to repair that through a reputable shop as I am not currently able to do some fabrication repair to my vehicle myself.
Thanks in advance.
Catalyst
Heated Catalyst
Evap System
AC Refrigerant
Thanks in advance.
