well you take the junk stock turbine and compressor out of the CHRA,
insert the rotating assembly and compressor backing plate/housing of your choice,
bore exducer dimension on your turbine housing/manifold on your milling machine,
cut up the stock turbine housing from the donor turbo you got your new turbine from to use as a pattern to grind a form tool,
stick form tool in boring head and cut the radius to the same depth as the stock one was to get similar blade clearance
play with the vane mechanism to figure out what size stop pin you need to keep the vanes out of the turbine wheel
send it out to have the thing VSR balanced as otherwise it'll die pretty quick (mine lasted about 15k miles of severe abuse going with just marking the alignment and resetting the wheels back the same)
Did that to stick a saab 2.3 LPT GT1752S assembly into my stock ALH 1749V turbine housing.
Doing it again, I'd just hack off the stock turbine housing and use stainless stick rods to put a t25 flange on the manifold. Run a saab 2.3 HPT TD04HL-15t-5cm with the wastegate actuator can hooked up to nothing. Much easier.
