mullenba
I'm a new owner of a 2002 Jetta with just shy of 300k miles. The previous owner said he thought the ECU had been reprogrammed and it had received upgraded injector nozzles. It runs excellent. I had the 100k service performed recently at a local import shop and now it smokes a LOT on startup, especially when cold. The smoke stops within about 15 seconds.
Other than the smoke, it runs perfectly. I'm averaging about 47 mpg, easy starts, etc.
How should I try to troubleshoot this? I'm thinking that perhaps when the shop did the timing, there was some issue with the way it was timed vs the reprogrammed ecu? Should I try to find a VCDS and adjust timing away from stock? I'm just really not sure how to proceed.
