Thanks for the fuel pump info guys. I'm going to go the T route for now, sounds like I'd be asking for trouble the other route. I'll keep an eye on the fuel temps, maybe I can add an inline cooler.
I was able to hybridize the left side Allroad intercooler mount with the
Passat intercooler mount and it just barely fits. The Allroad intercoolers are smaller than the Passat one, so it is a bit of a puzzle to get it to fit using the stock piping. Even the Passat ducting will fit, although I may have to trim it to fit the bumper cover.
The entire car has gotten lots of TLC and is pretty much back together. Some new suspension bits, new brakes on all corners and some new tires as well as painting and fluid filming as I go. I just need to find a replacement rear level sensor and it will be back on its wheels.
I received my ECU back from Ottostadt in Ottawa who is a Malone Dealer. I will still need to do some logging for the tune, but I should be able to get the car fully functional.
I punched a hole in the oil pan and added a oil level sensor. Since the 2.7T had one, there would be dash lights with out it. I may have been able to code it out, but figured why not, all the holes are in the casting of the pan. I'll need to run two wires up the the plenum connectors as the BHW ECU doesn't have the provision for it.
A little clean up to do, but everything should look factory by the end.
Just some repinning to do and then cross my fingers.
