Nash_TDI
Veteran Member -TDIClub Enthusiast
Bwhahahaha.Go kick his ass for me.
I'll see him in an hour. I'll be sure to pass that along.
Thats sounds about right for something with better aerodynamics. 2 or three of my trips on the 58mpg tank had 60-62mpg averages.Very impressive! I've been knocking down 64 mpg out of the Saturn TDI, then started experimenting with advancing the IP timing a bit in the ECU...hoping to get into the upper-60's with it. As of today I've gone 352 miles on half a tank, so it looks like I might get there.
The reason why I'm not pushing my tank into the 600-800 mileage range is because my AHU Jetta sending unit does pick up the last 2 gallons in the tank because of the G60's sending unit locking ring. I'm thinking in the future I'll be switching back to a fuel pump with a holly by-pass FPR like I did on my first tdi corrado. Right now I just don't feel like spending the money on a new pump and sending unit.
I used a PD lift pump in a mk3 2.0 sending unit with a 5/16" T of the vertical PD pump which is how I got around the height issue. I still have to pull the sending unit back out to modify the pickup further so It will use the whole tank..I end up running out by the time the low level light is on..luckily I don't generally use the reserve but you never know when it may be necessaryI was working on installing a MK4 fuel pickup. It is normally to long but I cut the locking tabs down so that it can compress further. The 2 remaining issues are the fuel level sender which works reverse of the MK3 sender and the fuel connections are not the same. If this can be modified to work then a PD lift pump may also be modifiable. The PD lift pump has the same issue with being to tall.
Do you have any pictures of the tee? Did you mean a elbow? I have seen others cut or buy the plastic fittings from the MK4's and slip the hoses over them. Does anyone know if those right angle connectors are available separately somewhere?I used a PD lift pump in a mk3 2.0 sending unit with a 5/16" T of the vertical PD pump which is how I got around the height issue. I still have to pull the sending unit back out to modify the pickup further so It will use the whole tank..I end up running out by the time the low level light is on..luckily I don't generally use the reserve but you never know when it may be necessary
best part is the gauge works properly
The clip slides in easily enough. But it usually just comes out again after sufficient flogging. That's why the "keystone mod" was created. I'm at work and can't show a photo now. Do a search here and you should find it.
We are going to redata log the car now that I've discovered the valve issue. It should be delivering more fuel now.Frank,
I had similar IP timing issues, both from the case relief valve and from air being pulled in through my thermostatic T on my CAT adapter.
It looks like you just need a minor tweak to your N75 duty cycle to make your actual boost match requested. More fuel might help too if you're not maxed out already.
I just got a new tune this morning for my BV43, boost comes up fast and nails request without going over, no boost valve here either.
Log channel 7 and 11 at the same time and do some 3rd to 4th gear pulls to see what your intake temps get up to. I had a theory that heat soak was causing me to loose timing on the top end but I did some pulls yesterday that showed me otherwise. I got up to 60C when trying to get the temps up.
I hope that mine doesn't have this issue when I put it together...
Sorry if that came off as fear-mongering. I'm a wise-guy and sometimes a cynic. I think Frank knows that. But many of you don't. I did not REALLY mean to suggest VW is clearing bad turbos out of their inventory. It's possible these turbos are so stinkin' reliable that they just don't sell many. So they put them on clearance to free up some shelf space.I guess now we know why VW's selling them for so little.
