what is a sputter bearing?
http://www.mahle-aftermarket.com/C12570B3006C0D49/CurrentBaseLink/W26MAE7Q320STULEN
Why is a sputter bearing the right solution?
A sputter bearing is composed of a three-material composite bearing which has a bearing layer that is not applied galvanically but by means of cathode sputtering. This coating method works only in a high vacuum. Smallest particles are knocked from the sputter cathode and propelled onto the bearing surface by means of high voltage. The coating is fine-grained, finely dispersed and adheres extremely well to the substrate material. Due to the small grain size, the produced layers are extremely hard with high yield strength and outstanding wear properties.
Where are sputter bearings used?
For highly loaded bearings, the bearing couples consist always of a sputter bearing and a conventional three-material bearing. The sputter bearing is used at the higher load end and the softer three-material bearing is used opposite. For connecting rod bearings, the sputter bearing is therefore fitted in direction rod and the three-material bearing in direction bearing cap. For main bearings this is exactly the other way round. The sputter bearing is here used in the bearing cap and the three-material bearing in direction engine block.
How can you recognize a sputter bearing?
Considering how complex and complicated the coating process is and how impressive the performance, it is difficult to see the difference in the sputtered bearings. They look completely ordinary. To make it possible to recognize the sputtered half-bearings, the sputter bearings are marked with the identification ‘SPUTTER’. This ensures correct fitting, especially as the correct assembly position of the sputtered bearing shells is crucial for reliable working and the service life of the bearings.
Why are sputter bearings and three-material bearings always combined in pairs?
One of the reasons is the high production cost for the sputter coating. At the location with low load, they are not necessary and are therefore not fitted. The second reason is the extreme hardness of the sputter layer, which does not tolerate engine oil contaminations. However, the softer three-material bearing can embed dirt particles in its galvanized bearing layer and renders them therefore harmless.
Why sputter bearings from the expert?
As the world’s largest piston manufacturer and development partner of the automotive and engine industry, MAHLE is highly competent in research, testing and production of engine components.
Sputter bearings are also used in the following engines:
Audi/VW series TDI: 1.9 / 2.0 / 2.5 / 4.0 / 5.0 l
Audi petrol engines: 6.0 l (W12) / 1.8 l (225 hp)
MAN: D2865
Mercedes-Benz commercial vehicles: BR 400, BR 500, BR 900
Mercedes-Benz passenger vehicles: CDI-engines BR 600
PSA series HDI: 1.4 / 1.6 / 2.0 / 2.2 / 2.7 l
Sucks I've already installed my pan and rod bolts. Next time I'll go sputter. Thanks for the info
028105701J connecting rod bearing shell upper/lower / AEY,AAZ,1Z,AHU,ALE
028105701J connecting rod bearing shell lower / AFN
028105701H connecting rod bearing shell upper / AFN
