GTiTDi
TDIClub Enthusiast, Macht Schnell! Vendor , w/Busi
- Joined
- Oct 18, 2010
- TDI
- '91 GTI CJAA swap,'02 Jetta wagon ALH swap, '03 GTI 1.8T rally car, '03 Sprinter 3500
I would not use red loctite on any fastener under 12mm in diameter...read the packaging for the red loctite...you won't be able to loosen those bolts unless you torch them
You can get silicone gasket material for making gaskets from the plumbing department..I think that would work perfectly especially since silicone is heat resistant..its orange and the amount that they sell is just enough for a few gaskets
