LukeWilson
I have had grand plans to put this back on the road, but I'm building a house and it's realistically not going to happen any time soon.
Here's a link the build thread:
http://forums.tdiclub.com/showthread.php?t=292227
Based on it's current condition, I would recommend that you use it as parts truck to swap into a clean chassis. The frame appears to be solid, but the body is quite rough from the rockers down.
The cliff notes:
-it starts and runs well
-the alternator is stuck, so the accessory belt is removed
-the clutch line or slave cylinder is leaking, preventing the truck from being driven
What you're getting:
-1990 Toyota Pick-Up registered in Ontario with a clean title
-1Z TDI engine from a 1997 Passat, resealed and new timing belt at time of swap
-.216 injectors
-Malone ECU tune, most I could get from a stock K03 turbo
-Digital EGT gauge
-Transmission adapter plate and flywheel
-Marlin Crawler 1600lb clutch, less than 10k kms
-TRD rear axle push-button E-locker
-Retread Mud-Terrains on Toyota alloys, less than 10k kms
The truck will need to be trailered, aside from the clutch issue, it's been sitting for a long time and likely has stuck brakes. If you're interested, it's be best to come and have a look.
Asking $1000CAD.
The cliff notes:
-.216 injectors
-Digital EGT gauge
Asking $1000CAD.
