So, will there be a Gen 3 fix?
Status
Not open for further replies.
Tri0de
Santa Rosa CA
2015 Beetle
And if so, will I be able to retune afterwards?
I've been reading threads here until my eyes are glazing over and can't find the simple answer(s).
Love my 2015 Beetle, want to keep it. Could not possibly care less about what CARB or the EPA want or don't want, just want to keep my car and have it run as well or better.
Any simple answers?
ZippyNH
Southern NH
2015 JETTA TDI SE
No simple answer...
Till it happens, nobody knows what the changes are 100%.
Seems like a added sensor or two, an extended warrenty, and a free oil change....
But till a tuner gets their hands on a car that was fixed...
They can't tell you they can undo it....
Will the ecu be locked down? Even changed?
Who knows.
fredthe
Bowie, MD
2013 Passat SEL Premium DSG, 2015 Golf Sportwagon SEL DSG
Personally, I expect there will be a Gen 3 fix, mostly an increase in SCR dosing and possibly some EGR operation tweaks. (along with a latter addition of a 2nd NOx sensor).
If you like it, you could always do nothing and keep it just like it is. I don't know what a tune would do, and what it could or could not do. Nothing needs to be decided right now, so you can just wait for reports from early adopters of the fix (if it actually happens).
If there's no fix, just keep driving and be happy!
scooperhsd
Kansas City KS
NB, 2000, RED(5 Speed conversion) 2015 Golf SE
I expect of all of them - the GEN 3's will be the easiest to bring close (or into ) conformity, at some unknown cost in HP/Torque and reliability/drivability (probably not much). IMO....
tadawson
Lewisville, TX
2013 Passat TDI SEL, 2015 Passat TDI SEL
Carb offical says "derrrppppppp . . . . ."
Please try to keep up . . . that's ancient and irrelevant . . .
Tri0de
Santa Rosa CA
2015 Beetle
Well I live in California, so just keeping it is not an option.
But thanks!
From what I can see it should only require a few software tweaks to do or undo.....
all replies much appreciated!
IFRCFI
Winchester, VA
2013 Touareg TDI Lux
Betting that you are wrong. What exactly is going to change CARBs mind? VW? Doesn't sound like they were impressed with the 3.0 "fix". It's not just software folks.
Please try to keep up...
Sent from my iPad using Tapatalk
tadawson
Lewisville, TX
Uh, the settlememt that is going to reduce the number VW has to hit, perhaps? Thus making a fix an almost certainty, and has already been documented in court paperwork?
No reason the 3.0 won't be treated the same . . .
fredthe
Bowie, MD
What leads you to that conclusion? Check out appendix D of the DOJ settlement agreement (which CARB is a party to), section 4.2.9. As long as you don't have a check engine light and aren't putting out smoke you're fine.
Status
