escore
I've seen a couple of theads saying you shouldn't have any bubbles and some saying alittle bubbles are ok??
I just installed a clear section in the fuel line going to the IP. When the the engine is running there is a steady stream of bubbles. About 1/4 in dia.Is this normal?? When the engine is off there is no bubble.
The car starts fine but I've been having a horrible erratic idle. and throwing a Quantity adjuster upper limit reached code. I'm thinking the code and the erratic idle is not related to the bubbles in the fuel line??
escore
escore
