A massive recall? Please.
Some people have had issues. MOST have not. Look, I service a ton of these cars and many past 180K already and none of them have had any issue sans one turbo at 125K miles.
The DSG transmissions, EGR coolers and cam/lifters in the 5.5-6 cars are FAR more trouble than the CR cars have ever been.
e
Maybe open up shop in California, if you want to see some failed HPFP's, since it leads the way in HPFP's grenading the whole fuel system. any person in their right mind is going to take a failed HPFP to the dealership to get it covered under warranty, certainly not to you, as the only way to pretty much get a replacement HPFP is through Volkswagen of America, and they are keeping a tight lid on inventory control.
In going down to my local VW dealership, I've seen 3 failed HPFP's in the service area on jetta's or JSW's, and 1 on a Touareg CR V6 TDI. They fail, believe it, just because you haven't seen it doesn't mean it doesn't happen.
Toaureg Failed HPFP. Picking up oil filters for my 2012 passat tdi SE when this was on the rack.
New fuel lines to replace the contaminated one.
Let's pull that pressure sensor to check the guts.
Shrapnel, this ones fragg'ed by a cam roller grenade.
3:2 timing belt arrangement for the V6, versus 1:1 on a Ford or GMC V8.
Let's send these injectors in for a full rebuild too, so that metal particles won't stick a common rail injector wide open and blow torch a hole in a piston below. New fuel cooler and new fuel pump too, junked by debris from a grenade frag job.
