DVF2001
I would like to get an opinion from the knowledgeable folks here. Please have a look at the photo and let me know if you think it needs to be changed. I hit a high curb with the rear driver’s side wheel and since then the alignment has been very bad and the steering wheel is about 30 degrees off center. The alignment shop said that the rear axle was way out of specification and I needed to go to a body shop and have the frame straightened. I could change the axle beam, but I'm wondering if replacing the bushings first may help the situation.
/img]
/img]
