TDI321
Got 2 amazon LED bulbs that claimed to be canbus-error free. not. Got the yellow bulb idiot light on so I removed it. I dont think the bulb even came on. This is a USA spec 2015 TDI prem SEL.
So - I will not cut into harness with ballast — as ballast temp goes over 220F usually. Is there a way to turn off the bulb check on DRL and still have the light operable? Or should I invest in the LED-turn signal housings that have to be manually wired into a fused connection to get some LED running lights ?
I’m surprised the 2015 SEL premium has no LED anywhere — when my 2006 audi had them everywhere behind the grill.
