Does the pump's crank have to be in any particular position when putting it in, or just look at how the current one is and put it in the same?
I do my own timing belt changes, have metalnerd tools, so that part is not a problem.
pin the IP, lock the cam, lock the crank (or be sure it stays at TDC when you tension the belt
I've only done this once, but I think it would difficult to just slip the belt back where it was without the lock-down.
