Old September 18th, 2018, 16:06   #16
scooperhsd
Originally Posted by GlowBugTDI View Post
if not what is one of the best oils I can get for my tdi?
With an ALH, you can use just about anything that is diesel rated - I'd stick to 5w40 / 0w40 synthetics, however.
If you don't need / want to stick to VW specs (VW 505.00 for the ALH), Shell Rotella T6 or Mobil 1 Turbo Diesel Truck have been popular is the past. I even ran one oil change with Rotella out to 15,000 miles.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old September 18th, 2018, 21:31   #17
GlowBugTDI
GlowBugTDI's Avatar
Fuel Economy: 43 mpg average
Okay thank you, I must have missed the fact that it was a PD engine. I recently redid the tappets under the cam, so I thought maybe oil selection may have been why they had gone out. Thank you for answering my question, I just want to make my car last as long as possible.
GlowBugTDI is offline   Reply With Quote
Old September 19th, 2018, 05:51   #18
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
Originally Posted by scooperhsd View Post
There is a reason that my nickname for them is "Iffy Lube" ....
You mean stiffy lube
Dannyboy is offline   Reply With Quote
Old September 19th, 2018, 06:33   #19
This isn't complicated, although some folks try and make it so. If you want to be sure you're using the right oil, look for one that has VW's 505.01 certification on the bottle. And make sure it has the certification, not some dodgy language like "made for engines that require" or "designed to meet or exceed," or "at the quality level of."
Castrol, Total, Pentosin, Liqui-Moly, and others have oils that meet this spec. Few of them are available in retail stores. But the dealer has Castrol, and others are available online. Easy!
Old September 19th, 2018, 09:18   #20
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Do you have Walmart or Canadian Tire anywhere near you?
Although Shell has not paid VW for a 505.01 certification, many people use Rotella T6 5W40 in their PD engine.
http://www.canadiantire.ca/en/pdp/sh...-0287935p.html
I have been using it for years in my 2004 Golf TDI.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old September 19th, 2018, 10:31   #21
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
I have been using a dino 15w40 in my PD, I now have 250km and the original cam
https://www.bosslubricants.com/viewp...-oils-api-cj-4
I have never been convinced that 505.01 was a magic oil, particularly when you read about all of the cam failures
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Old September 19th, 2018, 10:34   #22
Dino oil is a good way to coke the top piston rings. VW originally said dino oil was OK when they introduced the TDIs, but after rings got stuck and they saw increases in oil consumption they issued a TSB requiring synthetic in all TDIs.
Old September 19th, 2018, 10:39   #23
bluesmoker
bluesmoker's Avatar
I have heard this before, but to date (knock on wood) the engine has been flawless. No oil consumption, when I had the TB changed my mechanic said the engine was "spotless". In reality it doesn't matter to me personally, the car owes me nothing, if it dies I will replace it
My OCI is 6 months or 8000 km
Old September 19th, 2018, 14:28   #24
scooperhsd
I'll give you a VERY good reason for using 5w40 synthetic - Winter starting and the delays in lubrication using the 15w40. This is besides IBW's point on coking the piston rings.
Old September 19th, 2018, 16:22   #25
tikal
Fuel Economy: 37 MPG (~ 45% city)
Default Not all 5W30 oils are created equal
I would not get too stressed about using a 507 spec oil in your PD TDI either. Here is my explanation:
It is my opinion that sometimes here at TDIClub we have a 'Knee jerk reaction' to the debacle that happened to many PD cars in North America because many incompetent dealerships put just a regular 5W30 (synthetic or not) in the cars and contributed greatly to premature wearout of the camshaft. Therefore we concluded: "as long as the oil you put in your PD TDI is 5W30 you are doomed" or something similar. To a certain degree this is an understandable reaction. But if we do some research outside North America, in the continent that has far bigger pool of PD engines on the road, Europe, we see that many of the TDIs over there with Pump Duse engines (with or without DPF) used or are using a VW 507 spec oil (which is technically considered a 5W30 weight) for a cumulative miles/Kms in the range of millions and millions without the premature camshaft failures that PD TDIs experienced here in North America. Why you would ask this is possible if the viscosity is 5W30 that we have to avoid at all costs. The answer, in my humble view, is that not all synthetic 5W30 oils are created equal. As many of you are well aware of this no doubt. For a graphical explanation please refer to the following from Lubrizol Relative Performance Comparison Tool (https://online.lubrizol.com/relperftool/pc.html) comparing the VW spec 505.01 vs the VW 507 spec oils:
Now please understand that I do not have an interest that you use a 507 spec oil vs a 5W40 505.01 oil or a 5W40 HDEO one but I wanted to set the record straight that when we arrive at certain conclusion(s) we do not based it only on the very limited North American dataset but that we should be willing to research the topic worldwide whenever there is relevant data.
For a more technical explanation you can look at this very interesting thread from a European VW/Audi thread (specially posts 12 and 16):
https://www.audi-sport.net/xf/thread...engine.276227/
Also you may refer to Afton Chemical Specification Handbook (www.aftonchemical.com), the section dedicated to the VW spec oils which shows the much more stringent RNT Wear Test requirement that the VW 507 spec has vs the 505.01 one.
Originally Posted by noelchenier View Post
okay. so the oil that they put in last night was Mobil 1 ESP 5W30. It said on the bottle it's 505 01, but it's not listed on the latest techinical bulletin i can find.
https://www.anciravolkswagen.com/blo...d-Oil-List.pdf
Then I go on the mobil site, and here is what it lists for specs:
https://lubes.mobil.com/Canada-Engli...mula-5w30.aspx
Mobil 1 ESP Formula 5W-30 has the following builder approvals:
BMW Longlife 04
MB-Approval 229.31
MB-Approval 229.51
Volkswagen (Gasoline / Diesel) 504 00 / 507 00
Porsche C30
Chrysler MS-11106
Peugeot/CitroŽn Automobiles B71 2290/ B71 2297
GM Dexos
Mobil 1 ESP Formula 5W-30 meets or exceeds the requirements of:
ACEA C2, C3
JASO DL-1
According to Imperial Oil, Mobil 1 ESP Formula 5W-30 is of the following quality level:
API CF
Volkswagen (Gasoline) 502 00 / 503 00 / 503 01
Volkswagen (Diesel) 505 00 / 505 01 / 506 00 / 506 01
All VW engines with the exception of Unit-Injector / Pump-Duse TDI without LongLife Service and without DPF between 1999-2003 and R5/V10-TDi before model year 2006.
So I read that to mean that MOBIL feels it meets the 505 01 standard, but it's not officially approved by Volkwagen...
Am I correct here?
And if so...should I get the oil drained and filled with an approved one from the technical bulletin?
Sorry, I'm really stupid.
Noel
tikal is offline   Reply With Quote
Old September 19th, 2018, 17:01   #26
Chiroman
If the OP is looking for a VW 505.01 Spec 5W40, the local VW stealership may not be all that useful. I recently went to my local stealership looking for 505.01 for my 2005 PD. They gave me Castrol Edge Professional 5W40 with a 502.00 and 505.00 spec. They claimed the 502.00 replaces the 505.01 which is absolutely wrong. I asked to see the VW tech bulletin with this info, and all they produced was a photocopy of sheet stating that Castrol Edge Professional 5W40 meets VW spec 502.00, 505.00 and 505.01 spec, yet when you look at the bottle, the 505.01 spec is missing. However, there are lots of other good sources out there including the Pentosin from IDParts. Don't assume the stealership is giving you the proper information, do your own research.
My view is that some VW stealerships don't stock the 505.01 as there is a decreasing demand for this oil with the PD engines not having been made in 12 years, so they think the 505.00 is "good enough" and might help them sell some new cars, when camshafts wear. Funny, the juffylube place across the street had 502.00 505.00 505.01 Spec Oil, although it was a 5W30.
Chiroman is offline   Reply With Quote
Old September 19th, 2018, 17:45   #27
turbobrick240
turbobrick240's Avatar
Any CJ4 or CK4 rated 5W40 oil is going to provide excellent lubrication for the PD engines. Plus it's fairly affordable and available almost everywhere. That said, the 507 spec 5W30 is about as good a 5W30 as you could use. Personally, I'd just run the 507 oil out to 8-10k and then switch to CJ4/CK4 or 505.01 .
Old September 20th, 2018, 13:05   #28
belome
Fuel Economy: 47'ish
Original turbo?
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old September 20th, 2018, 14:20   #29
bluesmoker
bluesmoker's Avatar
Originally Posted by belome View Post
Original turbo?
yes and original cam
i changed to a dino 15w40 (hdeo) at 80 KM when I noticed the cam had some streaking on lobe #1, I thought the cam would die anyways
that was over 6 years and almost 200 km ago
still going strong
Old September 26th, 2018, 13:43   #30
hajes
don't worry about it...oil specs are for idiots who have nothing to do than arguing about pointless stuff.
I would say all oils are same...their basic composition is same, they may have different additives for different designs.
I used VW 505.00 Mobil One 5W-50 because it is the only one oil that showed excellent heat properties at high temps...then suddenly VW 505.00 spec disappeared so I have found Liqui Moly stuff. Of course there is racing oils such as Motul 300V but it is same crap for 3x more money...useful for racing teams where +0.1% makes difference.
Just read tech sheet and you will find more than some useless VW specs...don't forget manufacturer recommends they don't force to use it.
VW suggests 5W30 that is already too thin for VW engines and they had problems with lubrications earlier. I always used 5W40 and never added any extra oil or head problem with leaking. My first car used to have over 300k on ODO...my latest is heavily abused with over 250k on ODO
More important than oil spec is correct interval:
5000km if short trips are made
8000km combined
12000km max if driven at least 100km trips
engine oil, filters, including air filter are cheap and most misunderstood.
Basically, any cheap/premium oil is good for 10k km unless you drive short trips with TDi...you would be surprised but there is still many confused drivers that believe TDi is for driving 100m to shop.
Oil lab tests of Mobil 1 5w-50 showed promising results with 13k km at full load racing fun. I have never seen better normal oil so far. LiquiMoly is no where near Mobil 1...I wonder about last Liqui Moly special oil...we will see in 3000km
hajes is offline   Reply With Quote
first oil change on 06 jetta what went wrong jkenosh VW MKV-A5 Golf/Jettas 19 November 16th, 2010 13:59
Jack Daniels Vw Fair Lawn Nj Used Wrong Oil In My 2009 Jetta Tdi Abra Cadabra Fuels & Lubricants 61 April 9th, 2010 19:02
Wrong oil, wrong coolant too? - Jetta TDI 2009 Va6tmy TDI 101 15 April 17th, 2009 03:32
Wrong oil in 2005 Jetta TDI sheptonca Fuels & Lubricants 6 April 17th, 2008 18:36
A5 Jetta Oil Change - what did I do wrong? lildevildee Fuels & Lubricants 38 June 27th, 2005 19:12
Page generated in 0.20080 seconds with 13 queries
[Output: 141.95 Kb. compressed to 120.29 Kb. by saving 21.66 Kb. (15.26%)]
