Busydiver
I had an issue with the LED DRL not working on my HIS upgrade lights I installed 3 years ago from Ed...before I say more I never regretted installing these...With the help of a fellow Passat we disconnected the harness supplied with the lights from the car factory harness and there was significant corrosion inside the harness. Some of the wire entrance holes in the harness supplied with the HID lights were not completely sealed with silicone specifically the holes with no wires. Since there was significant corrosion 3 pins completely shattered in the light harness. Simple enough we proceeded to jump the 3 wires that no longer had pins and low and behold the LED DRL came back to life but I lost the HID low beam. To confirm what might be happening I am looking for information on the wire diagram for the harness. A long time ago I did see something but was hoping a member here would have the information.
