ndamico
Vendor , w/Business number
- Joined
- Mar 20, 2008
- Location
- Sacramento, CA
- TDI
- 2003 Golf 2Dr TDI, 2003 Jetta TDI, 2003 Jetta Wagon TDI, 2002 Duramax, 2003 Duramax
Ok,
i'm starting my own thread on this. I've read everything on here related to the DTC code as well as google and no joy yet.
Background- I have a 2000 Jetta (Immo 2). I have the SKC and did this same procedure on my 2003 Jetta (Immo 3) and it worked perfectly.
Ok, car came with 2 keys. I needed a 3rd so i bought one from the dealer and had them cut it. Upon programming with vag-com i get the blinking IMMO-key light on the dash all the time. originally all keys worked ut the light was always on. i went ahead and programmed the new remote to work and now all 3 remote's work no problem.
I've since gone back and tried to re-learn the keys to get the damn light to stop blinking, however now when i login and query group 21, it only shows 1 key and only 1 key works. i put in 0, test, save, the read, it shows zero, type in 3, hit test, it shows 3, then save, yes, close controller.
as i try to relearn the 3 keys it will only learn one now (and its one of the original 2 that came with the car).
today i tried only telling it i wanted to have 1 key, and used the one that has been working. oddly enought the IMMO-key light now goes out when it should, but i'm down to a car with 1 key so its clearly not a good solution.
according to the dealer invoice, its 1J0-837-246-D-ROH. the key half of the remote has no part # i can see on it. it has the HAA on one end just like the other 2 keys.
the remote itself has HLO 1J0 959 753 F on it.
Here's a pic:
also just to reiterate- i started with 2 working remotes. i bought a 3rd. the first time i programmed, all 3 keys would start the car, but each key would cause the IMMO light to blink the whole time the car was running. the 2 original keys still operated the remote functions. i then programmed it so that all 3 keys would operate remote functions. right now all 3 keys will remote lock/unlock/trunk just fine.
prior to doing this i had NO stored dtc's and no IMMO problems.
I appreciate any insight that can be offered!
Here are the directions i followed:
If this isn't the best section for this post please feel free to move it.
Thank you!
Here's a pic:
Code:
Procedure for matching keys to vehicles with Immobilizer in the Instrument Cluster:
(includes many 1999+ Golf/GTI/Jetta/New Beetle/Passat, also Audi)[LIST=1]
[*] [Select]
[17 - Instruments]
[Login - 11]
Enter zero followed by the 4-digit SKC.
For example, if your SKC is 1234, enter 01234.
[Do It!]
[*] [Adaptation - 10]
Enter 21 in "Channel Number"
[Read]
The "Stored Value" is the number of keys currently matched.
Enter "new value" of 0
[Test]
[Save]
This clears out the old key-matchings.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys
[Test]
[Save]
[*] [Done, Go Back]
[Close Controller, Go Back - 06]
Switch ignition off and remove key
[*] Insert next key to ignition and switch ignition on again
The warning light for the Immobilizer will light up for ~2 seconds, then go out
[*] Repeat step 4 with each key until all keys have been matched.[/LIST]
Thank you!
