1996 Passat Wagon
I just replaced my starter which got stuck (less than 1yr in service). Yesterday, after 4 days the second starter failed stuck again, ground and burnt.
I thought I had a bad starter but after the 2nd I think I have an electrical short or problem with ignition switch /ignition key cylinder.
another detail:
My ignition switch had failed 2-3 weeks ago (not even the trick of holding the key in cranck would do anymore) when the switch failed I noticed that the Key left in ignition Chime was ON whenever the door is opened even if the key is not in the ignition. I have replaced the switch but this odd behaviour continues.
I am not sure if I messed up the Ignition key cylinder (mechanical part) such that it might be changing the ignition switch state at will.
The radio also works with key off (even after the battery saver is disabled) but I don't remember if this was normal.
When the first starter failed the Instrument cluster went haywire for a while, I think the starter may have been acting like a unregulated alternator for a while until it burnt. but I haven't got a clue.
Battery is ok.
any ideas? thanks
another detail:
Battery is ok.
any ideas? thanks
