joetdi said:
What is the part number of the key that they sold you? Joe
Hi Joe,
according to the dealer invoice, its 1J0-837-246-D-ROH. the key half of the remote has no part # i can see on it. it has the HAA on one end just like the other 2 keys.
the remote itself has HLO 1J0 959 753 F on it.
Here's a pic:
also just to reiterate- i started with 2 working remotes. i bought a 3rd. the first time i programmed, all 3 keys would start the car, but each key would cause the IMMO light to blink the whole time the car was running. the 2 original keys still operated the remote functions. i then programmed it so that all 3 keys would operate remote functions. right now all 3 keys will remote lock/unlock/trunk just fine.
however i've tried to re-learn the keys a few times to get the light to stop flashing and it seems now all of my keys won't learn correctly. right now 2 of the 3 will start the car..the third starts and then dies. same dtc code as before. i think i can get all 3 learned up if i try, but that damn light is where i'm confused.
prior to doing this i had NO stored dtc's and no IMMO problems.
I appreciate any insight that can be offered!
Here are the directions i followed:
Code:
Procedure for matching keys to vehicles with Immobilizer in the Instrument Cluster:
(includes many 1999+ Golf/GTI/Jetta/New Beetle/Passat, also Audi)[LIST=1]
[*] [Select]
[17 - Instruments]
[Login - 11]
Enter zero followed by the 4-digit SKC.
For example, if your SKC is 1234, enter 01234.
[Do It!]
[*] [Adaptation - 10]
Enter 21 in "Channel Number"
[Read]
The "Stored Value" is the number of keys currently matched.
Enter "new value" of 0
[Test]
[Save]
This clears out the old key-matchings.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys
[Test]
[Save]
[*] [Done, Go Back]
[Close Controller, Go Back - 06]
Switch ignition off and remove key
[*] Insert next key to ignition and switch ignition on again
The warning light for the Immobilizer will light up for ~2 seconds, then go out
[*] Repeat step 4 with each key until all keys have been matched.[/LIST]
