Today was a good day!
KraftwerkB6
Lexington Ky
2010 JSW
How did the hoses fit on the car. This is something that I am seriously considering since the CW intercooler on my car was ineffective this winter. I have modded the car and no longer need the CW intercooler so this would be a good solution to remove it if there isnt a hose issue.
well they fit. but its very tight, and im looking into getting some made/buying correct length ones. i found a good site but have not taken the time to measure my hoses and what size i need.
I did what the 2.0Tgas guys are doing and cutting the metal quick connect ends off. kinda crummy, but i had another set laying around just in case.
KraftwerkB6
Lexington Ky
2010 JSW
I'm sure toeball or any other heaviliy modded ride can do a good pull in hot temps to give you a proper base line. Either way it'll just show you what you already know.
yea, i know what your saying. Maybe when it gets a little warmer someone can run some logs and look at heat and boost as well as IAT's.
and we can swap info.
