Does anyone have a supplier for a BEW valve cover gasket? I'd like to get just the gasket if possible. The places I've found have only had the entire set including valve cover.
Is it leaking or is this just for a camshaft inspection? The gasket is reusabel for a few times. Just put the smallest dabs (BB size) of silicone sealer in the corners where the camshaft bearing cap is. I have had absolutely no leaks reusing mine.
