Re: How much oil do you get if you use suction to pull the oil from the leads and bottom cavity of the oil filter housing?
Ans: It was about 12 ounces last time.
I will do an oil change at the Ft. Lauderdale GTG (getting my free dealer 10k "flush" Thursday) and we can measure the amount of oil retrieved by the "Tupper-Sucker" from the bottom of the oil filter cavity and the leads to & from it.
That 12 ounces is about 8% of the 4.5 quarts of new oil, and is not used dirty oil mixing with the new oil.
With the soot carrying capacity of the Delvac-1 I use, 8% is no big thing. Probably like changing your oil with used 1,000 miles when you don't use suction at an oil change.
I'm also curious to see if the oil still stays amber this time for 600 miles or so like it did before (when I treated the dealers' 5k oil change as a flush and also did the suction). The dealer's 5 k oil change went "dark" right away.
Re: Free "Tupper-Suckers" at the Ft. Lauderdale.
I'm afraid I cannot find any new TupperWare containers (Wal-Mart, K-mart, discount mall, etc...) in my area, so that I'll have to make up these devices from RubberMaid products. They'll be called "Rubber-Suckers", son of "Tupper-Sucker".
I'll make up 10 or 12 and give them away.
Sidesucker: I'll also be testing some prototype extensions of the "Tupper-Sucker" to pull oil, if any, from around the drain plug, which I will name "SideSuckers".
Going for that amber oil look as long as I can.
Cheers and See Ya!
Sierraent
Dick Baumer
