DbLog
At the track I've found the 225 reduces egt's 200-300f and gives a nice power bump. The 5.5L reserve is enough for a 25min session. Still had to lift on the straights due to EGT's so in goes the 375.
Agreed! with the introduction of meth (and the associated reduction of h20 in the mix as a result) your egt's are sure to rise. I'd definately be tempted to add increasing amounts of meth and log temps.mojogoes said:Jason if i were you i'd run the water/methanol mix first with the egt's you've menstioned to get a real indication of whats going on against how much power it will extract against how high egt's will be...........as it seems you may be able to run something close to a 50/50 with that nozzle plus the low egt's you already had...........just a case of trial and error adding more and more methanol .
Man, blow those storms down to the south west! I'm sat here, sweating at nearly 11pm, window wide open. Nothing is moving outside. Almost tempted to go out in the car just to cool down, driving at 100 with the windows down!20vK said:Right, must shut the door - just had a silver mk4 absolutely hoof it down the sidestreets of london past me & the biggest thunderstoorm is just about to arrive on my balcony!! much needed though - very humid @ the mo!!
devonutopia said:What kind of EGTs were you still seeing? Just curious as mine were low'ish before I installed this kit, so I'm going to have to a repeat run up my local motorway hill to see how it's changed. Mine seemed to peak out at 750 degC and never go above that. I'd only start getting worried if mine went over 900.
1600F Your begging for turbo failure or worse engine failure running EGT's that high, You need a larger nozzle for your kit, You should be able substain 1300F with proper nozzle size and set up even at WOT. You also might want to try a higher water mix like 80/20 or 90/10 for maximum cooling. Any power you gain with extra methanol is lost with the high EGT's.DbLog said:1600f (871c). A lift of the go pedal would bring them to 1300-1400 (725ish c) pretty quickly. Don't think the turbo liked it too much as now it is making a nasty whistle building boost. Gotta get the MKII reliable and start pulling things apart.
dvldoc said:1600F Your begging for turbo failure or worse engine failure running EGT's that high, You need a larger nozzle for your kit, You should be able substain 1300F with proper nozzle size and set up even at WOT. You also might want to try a higher water mix like 80/20 or 90/10 for maximum cooling. Any power you gain with extra methanol is lost with the high EGT's.
I would highly suggest a second pre-turbo nozzle 2gph or so a larger nozzle than what you have installed in your current location.
Anouther thing is you might want to consider getting a Downpipe. But you can bet your turbo is going to take a dirt nap with 1600F EGT's and road racing.
I would start at about 12psi start point and full at 24psi. I would be more into the cooling on that set up. I would try out 70/30 for the mix. Your EGT's are what you need to monitor to figure out what is working best for you as well as knock and if your loosing any timing.20vK said:DVLDOC, thanks for your reply to my PM
What sort of psi should I start injecting on a 300bhp setup (PD engine, GT25 turbo), with boost @ say 28psi and also, the start WI start psi on the same engine, but running, say 35 - 38psi? Would around 15psi and 18psi sound about right?
How about with 50:50 h20:meth and 100% h20? Does that change things?
Cheers,
Rich
Any technical reason why? Just wondering I used a aluminum 8qt tank in my Grand prix GTP for 3 years, running washer fluid which is 40% methanol, Never had a bit of corrosion. Replaced it with one of our 6 gallon tanks just for less refills.DPM said:try the same test w/ 50/50 methanol- water, might come out different...
unlikely since winter washer fluid is 40% methanol- wouldn't damage to exterior aluminum pieces on vehicles be common knowledge by now?DPM said:try the same test w/ 50/50 methanol- water, might come out different...
Jason what do you feel the methanol snow performance kit has given you in terms of extra power reduced smoke etc etc...........if you've stated i appoligise as i must have mist it.devonutopia said:I use a Snow Performance kit. Not going to bother going into detail here but if you search "methanol" it's bound to bring up something.
Unsure but it feels good. Dyno'ing in Portsmouth on 7th Feb where I hope to do a run with it turned off, then the last 2 runs with it flicked on. For comparison's sake.mojogoes said:Jason what do you feel the methanol snow performance kit has given you in terms of extra power reduced smoke etc etc...........if you've stated i appoligise as i must have mist it.
