Prke Bg
Hy,I got a problem.My engine code is bkp with siemens electronics 140hp,now I got injectors from 2.0tdi 16v 170hp and I have a problem with smoke,all the time when engine coolant temperature is less then 80c.A loot off smoke smell on diesel.I have hybrid turbo 1749,full open exsaus and around 220-230hp.car goes well, the only problem is smoke until the engine warms up to operating temperature. I replaced the cylinder head, took off egr ...
pls help,I can send You my map,log...
