Redneck Truck
Gone, but not forgotten
- Joined
- May 3, 2009
- Location
- Plano, TX
- TDI
- 2008 Touareg V10, 2001 Audi TTQ Roadster TDI 6-speed, 2005 Jetta Wagon TDI 6-speed
In planning my TDI swap into my Jeep Cherokee, it has become apparent that the current belt routing won't work, due to clearance problems between the front differential and the A/C compressor. I'd like to install accessory brackets, accessories, starter, and a flexplate adapter from a 2005 Passat TDI, but was recently told by a salvage yard that these parts do not interchange (2005 TDI vs ALH) and are as different as Ford and Chevy. Does anyone know what will interchange between the two engines, and to what extent? Think motor mount brackets, oil cooler/filter setups, bell housings (bolt pattern only), accessory brackets, alternators, accessory belts.
