I originally posted this as a new thread cause I didn't want to add unneccessary posts to this fine thread.
The issue I'm having is I'm not getting voltage at the compressor, here's the story: I got lazy and decided to take my car to a local shop that only works on AC. This shop rebuilds compressors, builds hoses, does installation and will also install AC on classic vehicles. Since they’ve been around a while I gave them a shot.
The compressor was replaced and the system recharged however the clutch would not engage. A mechanic from a shop a few bays down offered advice to the AC shop owner that the Fan Control Module probably needs replacing (how did he know this?). So I went to the dealer and bought one for $100, after installing it the AC still didn’t work..it figures. So I logged on, searched and found this thread
Here's what I've done so far:
New compressor, charged, w/new J293 - OK
All my fuses look good - OK
My fans do not come on when the AC switch is on - BAD
My fans work in slow and fast speeds when I jump the T4 terminals - OK
I have zero volts at the compressor unplugged - BAD
I have 12v on T14/8, T14/9, T14/4 - OK
On T14/3 I have 0.6v at idle, 14v at 2500rpm and voltage does not pulsate – BAD, BAD and BAD
BTW, I bought a Fluke 8021b Multimeter many years ago that I used only to check voltage, I’m not aware of all of its features or how to operate them or even if it can measure Duty Cycles; so I ordered an owners manual from ebay, it should be here around July 8th
Now that I’m going over my notes and Dans troubleshooting guide, I noticed I've neglected to check compressor voltage under load, but since there's no voltage coming in what's the use. My next step was to unravel the compressor wire loom to see if there are any breaks and to see where it leads. The wires from the compressor leads to a four prong connector above the starter, I check it and found wires 1 & 2 have 11v, wires 3 & 4 have zero volts. I traced two wires back to the alternator, unplugged the two prong connector, they both test at 12v.
I started cutting the loom apart at the base of the battery but stopped as I felt there may have been something I missed or a cleaner way of locating where the compressor wires go. I checked the Bently but couldn't locate the correct wiring diagram. I remember reading something about another solenoid somewhere?
Any advise on what the next step should be?
