it started by itself. it continues honking at the traffic lights like I am an impatient jerk. stealer says thursday for appt. there has to be another answer.
When you do push on the horn, does it give or is it flush up against the wheel like you were already pushing it as far as it goes?
Try disconnecting the battery and removing your airbag to see what the deal is with the connectors. If I recall, there are four on each corner of the airbag unit.
