Outsider
- Joined
- Jul 4, 2001
- Location
- Tooele, UT, USA
I installed the Evry fuel mod today. Works great with a 1k resistor (980 ohms actually)soldered in place across wires 2 and 3, with a little disconnect thingy from radio shack in case I want to remove it. The only problems is I get the stupid code BillW mentions- after a sort delay. After the car starts, it is ok for about ten seconds, then the glow plug light starts to flash, followed by steady CEL a few seconds later. The strange thing is that the CEL and GP still act up after I removed the resistor! Everything in the car is stock but the 1k ohm 1 watt resistor and a few fender lining vents. Perhaps the resistor has too low a power rating, so it is ok until it gets hot from a little current.
