Andyinchville1
Hi all,
Just thinking the other day how to make the car warm up faster since I hate freezing in the mornings... and it would help mpgs to boot (faster warm up).
My idea was to buy an exhaust cutout assemby and use it on the intake system ( 1 side of the cut out would breathe cool air from the outside and 1 side would Breathe warm air from the engine compartment or maybe rig up that side too suck hotter air off the exhaust manifold ( of course would assume having the under belly pan and side skirts in place) .
If I suck hot air off the exhaust manifold how hot is too hot for an intake ?
I realize that the EGR setup is to get hot exhaust gases into the intake as well but if you think about it it would be blending in cold air from the outside with a factory setup and that's why I'm taking of having a system to also ingest hot intake air as well
My thermostat is fine and I do have winter blocks on my grills...
What do you think of this idea? Has anybody already done it if so what were the results?
Most exhaust cutouts tend to be an either-or proposition it would be nice to have one rigged up in such a way that it can vary between fully opened and fully closed...
I do have a ScanGauge to monitor intake air temperatures
Thanks in advance for any and all help
Andrew
Andrew
