2006 jetta tdi no a/c
DanG144
Chapin, South Carolina, USA
2005 A4 Jetta 5spd
The small fan has two wires to it, from the back of the large fan. You can run 12v directly to it. The large fan is a different story, not easily done, as it is fed directly from the PWM converter on the back of it.
zleem60
Queen Creek, AZ
2006 Jetta TDI w/ 5th gear swap .658, 2002Jetta Tdi six speed swap!! :)
Thanks for the feedback.
I was pretty sure that the oil addition would not be a panacea.
Looking forward to find if the RCV fixes it.
Dan,
I received the RCV from the vendor and it was the wrong one. MY AC is a Sanden but newer model than the RCV I purchased. So back to ordering a different one to see if that fix the problem. Also, I've tried using Pag 46 with ICE32 3oz, made no difference. I'm going to wait for the new RCV to arrive and try to put the ICE32 straight into the compressor. I know I'll get it right one day..
Thanks,
Mike
caper7
Sydney , Nova Scotia
2013 highline ,2006 jetta tdi
Hey the connectors for the fans is on the electric block down on the bottom of fans left side.. You can pull the block appart and take a battery and make contact and fans should spin . I forget the color code
