Hi, I was able to adapt the additional springs from A6 (about 30€ total for both springs) to my passat 3BG. These springs open the boot completely, and not just the "pop" of 0,5 centimeters. The 3B works the same... maybe other models like jetta, a4, a6 (without this feature)
I had to build some parts from the scratch, using some pieces of iron... it is not finished yet, since I want to improve it a bit before publishing the shape and dimensions of the pieces... The hard work is to find the exact position to drill the holes, the length of the pieces, etc... since I had to rebuild some pieces several times. And still a bit more improvement is required, to be perfect.
So at the moment I will show you the final result of the initial successful test (you cannot imagine how happy I was to see THIS after 10 hours of fighting with the driller and the radial tools, etc... screwing and unscrewing... pffff...
I promise to give all the details about the 4 pieces that are needed (for each side). Having the perfect dimensions and shape, it is about 1 hour to build and install... Additionally you will have to buy the springs at Audi dealer... not expensive for what you get.
I hope that you like it:
http://www.youtube.com/watch?v=-1Vw6t0FC5Y (high quality available)
I wrote a bit more info in a local forum... but you can take a look to the pictures of the parts involved, etc... http://www.solovag.es/viewtopic.php?f=15&t=534
My car is actually at the workshop, since someone came too fast towards my rear bumper... breaking it... the led tail lights saved from the accident so right now I cannot work on it until next week...
