Slave2school
I extended the antenna in the car so I wouldn't have to look like I was a deranged psycho path most of the time...except for when I'm cursing at the shed for not opening with the remote.
Wondering if anyone has good solutions for replacing the rear tweeters?paramedick said:Installed new Blaupunkt speakers in the front doors. Popped off the dash grilles to assess possibilites for speaker replacement there.
New tires came in, just awaiting the Corrado rims from IMPEX.
You really like this ride alot don't you?IndigoBlueWagon said:Got the '99.5 Golf aligned, after mr chill installed Shine springs, Shine Race rear bar, Koni Yellows, SPC adjustable mounts, subframe and upper strut braces, TT bushings. I've got about 1.6 degrees negative camber with the mounts set at one extreme, stock at the other.
Thanks!IndigoBlueWagon said:Splendid is right. And now it has a GHL downpipe--2.5" turbo to tail, Magnaflow diesel cat only. Not too loud, just nice. Brian, I'll get back to you on your suspension bits shortly--And I can rattle chill's cage for you, too.
Could you explain this to me? If my I.Q was brought down to 3.0 w/sprints and it smokes like a bandit... that would mean by reading your post -to rid the smoke you have to RAISE the I.Q.?IndigoBlueWagon said:I had bumped the IQ up to 5.0 this morning to reduce the smoke which was pretty heavy at WOT. And the OMI helped further, but I've moved it up to 6.0 because I know I'll be flat footing it a lot on the track and don't want to get black flagged.
That is correct, higher IQ means less fuel.BrianCT said:Could you explain this to me? If my I.Q was brought down to 3.0 w/sprints and it smokes like a bandit... that would mean by reading your post -to rid the smoke you have to RAISE the I.Q.?
I'm confused.
Next weekend begins the stripping of its 1.6na diesel engine and trans. The it's a total frame strip down and some rust removal/welding/body work!mtltdi said:That's a beaut!
What makes it such a nightmare? Is it a hard swap to do? I'd love a more aerodynamic, lighter car with an ALH engine...it'd get 60 mpg without even having to try hard.edjet said:Went to look at another TDi project car, and then help the seller with his nightmare, a 98 Tdi Jetta with a ALH engine installed.
