Old January 31st, 2019, 12:45   #11191
YZO024
TDI(s): 01 Jetta TDI
2 weeks ago we had one station in Angleton TX, that was $1.99 gal. Now that I got my TDI back up and running they are back at $2.39 in the same area.
YZO024 is offline   Reply With Quote
Old February 4th, 2019, 02:00   #11192
Tom Servo
Tom Servo's Avatar
Fuel Economy: ~40 mpg
Prices in my neck of Baldwin County are still higher than the rest of Alabama…
Regular is averaging around the $2 mark with diesel around $2.65.
Cheapest around here is the new Buc-ee's that just opened about 20 minutes north of here. The first out outside of Texas! Their regular was $1.879 yesterday, and diesel was $2.459.
I spent over two hours there with a family member who spent way more there than I am comfortable admitting to anyone!
It was pretty impressive, though. I think it has well over 100 pumps, all of which have diesel nozzles. Selected ones also have ethanol free fuel and DEF dispensed direct from the pump, which is not something I've seen around here before.
~Zach
alabama broadcast media page
Tom Servo is offline   Reply With Quote
Old February 4th, 2019, 09:50   #11193
hugho
Fuel Economy: 52.3 on first tank
Default Diesel/gasoline spread
Here in Wyoming Diesel is about 30 cents over gasoline or about $3/gal. Nationwide the average is 60+ cents according to the website oilprice,com. The spread is likely to increase as diesel is refined from the heavier crude grades. Not as much diesel in the Frack grades. Heavier grades tend to come from Mx, Venezuela and Canada. Heavier grades are showing a premium to the lighter grades per barrel. Marine shipping is moving to low sulfur diesel this year increasing diesel demand. I would look for diesel prices increasing relative to gasoline unless demand worldwide collapses.
hugho is offline   Reply With Quote
Old February 4th, 2019, 11:51   #11194
kjclow
In SC, diesel came down a dine to $2.49 and rug went up a dime to $1.99.
Old February 4th, 2019, 13:59   #11195
93celicaconv
hughho, I understand most of your response above, and appreciate your insight. I don't think I under stand the last few sentences though. Would appreciate your thoughts on my questions below:
What is Marine shipping using now?
Also, regarding diesel demand, how is it that the US EPA / CARB are forcing road transportation away from diesel (due to very strict emission control standards), yet the marine shipping industry is looking to increase? This seems contradictory to me.
93celicaconv is offline   Reply With Quote
Old February 4th, 2019, 14:57   #11196
JimInPB
Fuel Economy: 47mpg
... Marine shipping is moving to low sulfur diesel this year increasing diesel demand. I would look for diesel prices increasing relative to gasoline unless demand worldwide collapses.
It was my understanding that large ships only burned sweet fuel when inside of territorial waters & they instead burned cheaper/dirtier bunker fuel when offshore. I don't have real numbers to work with, but I would expect that the low sulfur (sweet) fuel would only account for 5% or less of the total fuel that they burn on average. An effect will likely be seen, but it may not be a gigantic effect.
JimInPB is offline   Reply With Quote
Old February 9th, 2019, 19:52   #11197
Tankthecarman
Tankthecarman's Avatar
Fuel Economy: 42-48
Was 2.859/Gallon when I filled up last week here in the suburbs of Savannah Georgia .
Tankthecarman is offline   Reply With Quote
Old February 9th, 2019, 19:55   #11198
Tankthecarman
Fuel Economy: 42-48
As an aside...has anyone ever heard of adding a half-pint if 2strike oil to the tank for its lubrication qualities? Was told that it helps keep the fuel system and associated parts conditioned in a low sulfur fuel environment. Is there any merit to this?
Old February 9th, 2019, 19:56   #11199
Tankthecarman
Fuel Economy: 42-48
*2-stroke*
Old February 9th, 2019, 20:03   #11200
romad
romad's Avatar
Originally Posted by Tankthecarman View Post
As an aside...has anyone ever heard of adding a half-pint if 2stroke oil to the tank for its lubrication qualities? Was told that it helps keep the fuel system and associated parts conditioned in a low sulfur fuel environment. Is there any merit to this?
I believe that has been discussed in this forum:
http://forums.tdiclub.com/forumdisplay.php?f=14
particularly here:
http://forums.tdiclub.com/showthread...=equals+smiles
The fleet:
romad is offline   Reply With Quote
Old February 9th, 2019, 21:55   #11201
rotarykid
rotarykid's Avatar
Fuel Economy: 64 .1city @ 30-60 mph/ 52-53 @ 70-85 mph hyway ( 52 to just under 60 normal around town)on LSD
Arrow
I add a bit of auto trans fluid in every tank. Currently I am using type-4 atf that I got out of a jeep trans...
More diesels than I can list
rotarykid is offline   Reply With Quote
Old February 16th, 2019, 08:13   #11202
Ton
Fuel Economy: 42-51
$2.79 Shenandoah,VA Diesel. $2.09 gas.
Ton is offline   Reply With Quote
Old February 16th, 2019, 10:45   #11203
El Dobro
El Dobro's Avatar
Fuel Economy: 115 MPGe
$2.23 for RUG and $2.93 for diesel at the local Speedway.
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
"He's opening our minds to new ideas, KILL HIM!!!" -Futurama
Now, I drive more, worry less.
Penguin -The other white meat.
El Dobro is offline   Reply With Quote
Old February 16th, 2019, 12:22   #11204
TornadoRed
TornadoRed's Avatar
Crude prices are going up, gradually. WTI at $56, up about $13 from the December low, Brent at $66, up about $14. So ULSD futures are up about 35 cents and RBOB futures up about 30 cents.
Not sure what will happen in March and April with the switch to summer-blend gasoline. There is so much gasoline in storage, but refiners keep processing crude because diesel is so profitable.
'03 Golf with 745k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, TDT or Delvac1
Like TDI Club? Got PayPal? Got $1 or $5 or $10? Contribution link on the main page.
Old Yesterday, 19:09   #11205
Ton
Fuel Economy: 42-51
$2.85 for Diesel fuel in Shenandoah,VA.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Page generated in 0.32142 seconds with 11 queries
[Output: 125.91 Kb. compressed to 104.85 Kb. by saving 21.06 Kb. (16.73%)]
