Go Back   TDIClub Forums > Forum and Web Page Info > TDIClub and TDIClub Forum News, Issues, Problems and Suggestions
TDIClub and TDIClub Forum News, Issues, Problems and Suggestions This is the place for updates on the website and forums. This is also the spot for forum questions, comments, ideas, gripes, requests, etc. This forum is NOT for posting problems about your car. Non-topic posts will be moved or removed.
Old January 9th, 2019, 01:52   #1
ejoskf
ejoskf's Avatar
Default Belt tensioner bouncing after replacing
Hey guys. I've got Passat 2004 1.9 TDI PD and tensioner for alternator and power steering failed. I've replaced it with both new belts. I've noticed new tensioner is bouncing 2-3mm on idle. Any suggestions please? I have checked alternator clutch pulley it is free spin in opposite directions and locked at direction of engine spin. Could it be that's on the way out or anything else that could cause it?
Thank you
Sent from my CLT-L09 using Tapatalk
ejoskf is offline   Reply With Quote
Old January 13th, 2019, 13:36   #2
ejoskf
ejoskf's Avatar
Updated. I've tried to replace alternator pulley how's could not get it off no matter how hard I've tried even alternator off the car and impact gun it was solid. I was confident that is the problem as alternator pulley had a wobble. I've replaced the entire alternator and the problem is still there. Pulley vibrating a bit about 1-3mm on idle. I'm starting to think that that's normal now. Only thing that's original there is power steering pump and fan. Any ideas?? 85 000 miles 2004 Passat.
Old January 13th, 2019, 13:55   #3
Vince Waldon
Vince Waldon's Avatar
"Normal" is kinda in the eye of the beholder, but there are some pretty good eyes on this forum, so if you post a quick cellphone video I bet folks will be able to spot if you're ok or not.
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old January 13th, 2019, 15:05   #4
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
ejoskf
This is the wrong thread for car problems.
You'd get better and faster results posting this in the appropriate forum thread.i.e
The B5 Passat thread.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Old January 14th, 2019, 04:57   #5
ejoskf
ejoskf's Avatar
Thanks I've posted to B5 Passat. I've asked mechanic and he said that's normal for tensioner to vibrate up and down when engine running.
Belt tensioner bouncing after replacing alternator pulley? mtn-wagon VW MKIV-A4 TDIs (VE and PD) 30 August 13th, 2018 10:35
Replacing Serp Belt Tensioner Problems newedgesvt VW MKIV-A4 TDIs (VE and PD) 10 April 14th, 2015 16:36
Serpentine belt tensioner bouncing........ ItsADiesel TDI 101 7 April 20th, 2014 02:06
Bouncing belt tensioner BenzOil VW MKIV-A4 TDIs (VE and PD) 27 June 21st, 2012 17:32
Replacing my belt tensioner Troels VW B5 Passat TDIs 1 November 19th, 2010 12:16
Page generated in 0.12391 seconds with 12 queries
[Output: 69.90 Kb. compressed to 61.86 Kb. by saving 8.04 Kb. (11.50%)]
