Old February 5th, 2018, 18:07   #1
EcoDiesel
TDI(s): Eco Diesel
Default 04 TDI to 01 GLS
I have purchased a wrecked 04 TDI 4 door golf MT and a 01 2.0 AT. Looking at swapping the tdi into the gas shell. Planning to swap as much as I can from TDI. Any known issues I will run into? I plan on swapping the cluster, ignition, and ECU from the TDI. Anything else I should look at. The tdi did not come with sunroof or heated seats, but the 01 has them. Looking for some info of stuff that I am not thinking about during the swap.
EcoDiesel is offline   Reply With Quote
Old February 6th, 2018, 22:48   #2
vwztips
vwztips's Avatar
Need to be clearer.
What is rhe 01 2.0 AT from?
What gas shell are you looking to swap into?
vwztips is offline   Reply With Quote
Old February 7th, 2018, 04:43   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You'll need to swap just about everything, as there are a few more items that changed 2001-2004. Even things like the radio wiring is different, so plan on yanking the dash out.
Basically strip the 2001 down to the bare shell (you can leave the glass in, and the doors can probably be left alone). Then you can see what all is different.
It would be easier to find a 2004-2006 Golf, even if it was the gas engine, to swap stuff into.
oilhammer
www.cardocautomotive.com
Old February 8th, 2018, 19:28   #4
EcoDiesel
TDI(s): Eco Diesel
The TDI is from an 04 4-door golf 5-speed was hit hard on the passenger side. The passenger side strut tower is slightly tweeked and the the front frame horn is bent down from the wreck. Hooked the battery charger up and it has 175k. Motor looks pretty clean, doesnt appear to have any major leaks.
So I found a 01 4-door golf that the owner said had a knock in the motor. Working on pulling the wiring now to get the motor out. The interior is already stripped down to the dash.
The 04 has no sunroof and no heated seats. The swap car has a sunroof and heated seats, i would like to keep them functioning. It will be a little fun on wiring everything.
I plan on stripping everything changing everything over from the donor car.
Old February 11th, 2018, 19:29   #5
EcoDiesel
TDI(s): Eco Diesel
Decided to scratch the PD in the 01 because the intier was pretty well off. I did not want to tear it all apart to get the wiring to transfer over. Therefor i have picked up an 01 GTI and to swap the PD into. For the 4 door golf, have decided to purchase an 02 4door to utilize the motor and trans out of and produce a 01 4 door golf.
When i get to working on the GTI, my build will be logged and put into the forum.
04 Jetta wagon GL parts to 04 Golf GLS coalminer16 VW MKIV-A4 TDIs (VE and PD) 3 January 29th, 2016 15:24
FS: 01 Golf TDI GLS and 02 Beetle TDI GLS...both automatic & silver alatdi TDI Cars for Sale/Wanted 1 March 22nd, 2007 08:03
'04 Golf TDI, Should I switch to 506.01? Bayou Fuels & Lubricants 11 August 12th, 2006 21:28
WTB: 01-04 Golf GLS TDI Manual in New England Are Hope2OwnaTDI TDI Cars for Sale/Wanted 12 May 19th, 2004 12:06
Page generated in 0.13052 seconds with 11 queries
[Output: 67.67 Kb. compressed to 59.90 Kb. by saving 7.77 Kb. (11.48%)]
