Some basic information, numbers and safety tips
This post is not aimed at recent posters; I just placed it here after reading some other posts in other threads. Some people are doing dangerous things - adding refrigerant with only a suction (low) side pressure gauge on a can.
Remember this is for Mk IV cars.
Our cars do not have a switch or sensor on the low pressure side of the system. This is not a 95 Suburban - systems have changed a lot.
The compressor suction pressure can range as low as 17 psig per the Bentley; I see 25 to 35 most often here in South Carolina when it is warm enough for people to be checking the AC system out. But suction pressure has very little to do with how much refrigerant charge you have - almost nothing, in fact.
Our AC systems have a high pressure sensor that provides fan control and compressor interlocks.
If HIGH side pressure drops below 15 psig, the compressor turns off, when it gets above 70 psig it turns on (clutch engages) again.
If HIGH side pressure gets up to about 450 psig the compressor turns off, it turns on again at about 350 psig.
If High side pressure gets up to about 550 psig then the safety valve blows off - if this fails then something breaks - often with disastrous results.
Cycling on the high pressure interlock. This is not a healthy place to operate. For actual pressure to get this high you have either severely overcharged the system or temperatures a much too high (your fans are not working, or the condenser coils are fouled.)
If it is due to overfilling the system and your high pressure interlock delays about 100 milliseconds then you will blow off your relief valve. If that fails then in another 50 milliseconds you will explode your compressor or line - it runs about half and half.
It is DANGEROUS to fill a system with only a low pressure gauge. Those cheap kits can destroy your AC system or kill you.
The ONLY proper way to charge a system is to evacuate it, then add a known quantity of oil and refrigerant.
I think that you should either do your homework, and buy the minimum equipment to safely do the job, or leave it to experts.
You can educate yourself on basic car AC refrigeration cycle operation in a couple of hours. Our systems are the more modern systems that have Thermal expansion valves (not orifices) and high pressure sensors (not low pressure switches).
You can then study up on troubleshooting details of our systems by reading the documents linked in post #1
here. These were not written for study guides or system instruction and are poorly written even for their intended purpose - but they are the best I can point you to.
