loganbmx4gt
Get rid of that K&N air filter if you don't want to replave MAF sensors for the life of the car.I'm at my wits end. The problem is a long crank time to start, at least 5 to 8 sec. It happens if the engine is hot or cold, including directly after use at operating temp. Clearly not a glow plug issue because even if the engine is off for only a few minutes, the long crank time still occurs. After engine is started, everything is in order, no unusual smoke, runs normal. Engine is basically stock less EGR delete and a K&N air filter. Some times a mix of about B20. I've checked all the basics. A long list of things I've checked: Timing is slightly advanced. The IQ is about 4. I've eliminated the cars fuel system by putting container of fuel in eng. compt. and running pick-up and return lines to it. I use clear fuel lines to and from the fuel filter to the IP with no sign of any bubbles. Also I checked the little pressure regulator on the IP. Any ideas what to try next would be greatly appreciated.
Tuners have a Hot Start tune that fixes the flaw in the ECU that the 98'-99' ALH TDI's had.
