TDIpurdue
you can thread the wire into the engine compartment throught he gromet by your brake pedal, just pop it out and feed the wire through. You can reinstall the gromet by cutting a slit into it and sliding it over the wire.
any red wire? i think most wire bundles carry +12V in the passenger compartment. you can always verify with a voltmeter, either by seeing if there is resitance to ground, or by being cautious and probing while its hot.Fortuna Wolf said:Thanks. There are tons of pics on what pins to put the wires on into the harness and how to tune the mod, but apparently I haven't seen anyone discuss how to get the wires into the passenger cabin for a switch.
Last question still - where can I connect this 12v line? Either name a safe place in the cabin or the engine compartment. And no, I don't want to stick it to the battery terminal
not I. you could have a relay switch between sensor input and a preset resistor value at the push of your button. all you will need is a single wire connecting the relay with a positive voltage somewhere inside the cabin.FirstVtwin said:Can this be wired to a push button for something similar to a NOS setup? I would prefer something like that for the extra kick when I need it, but normal fueling for day to day driving. Anybody see any negatives to that type of set up?
TDIpurdue said:you can thread the wire into the engine compartment throught he gromet by your brake pedal, just pop it out and feed the wire through. You can reinstall the gromet by cutting a slit into it and sliding it over the wire.
lol i wander with all my mods, how much "fun" would the teenage get covered with...Fortuna Wolf said:But it is fun for when you're at a stoplight next to a stupid teenage ricer and want to cover them in soot.
