Faberktor
I have a 2001 jetta 1.9 tdi mkiv alh 5 speed std. I found a video of an egr delete with a race pipe. I have done a “home made” egr delete of the cooler and piping and simply made a cap plate for the egr at the “throttle body” and turbo, and rerouted the coolant lines. This would emulate installing a “slightly restricted” race pipe but keep the anti shudder valve operational. This format causes a cel with code 17965 overboost and 19586 egr. I removed my cap under the “throttle body” egr valve, put my fingers under the egr with the engine running and found intake air escaping at idle, and no air escaping when throttle is “snapped” or when the vacuum line to egr is removed. With the plate removed I do not generate a cel, however leaving this plate off/open does present some “spray” of fuel residue down the back of the engine, so my cap must stay installed.
I can’t find any “overview” of the egr system with bentley or on-line, and I am having some difficulty understanding the working of the egr system. It would seem that the egr system also seems to be used to regulate the MAP of the intake in allowing some reverse flow back towards the exhaust egr cooler when vacuum is applied to the egr, and no "back flow" when vacuum is removed either by pulling the hose off the egr or during "snap" of the throttle when intake vacuum drops. I am reasonably new to TDI’s, but on most (older) gasoline egr systems, the egr is not operated until the engine has reached operating temperature. This does not seem to be the case with TDI’s. TDI’s seem to use the egr flow to aid in engine warm up, so the egr operates/is available, right from start-up.
My engine obviously has more power (boost) with my cap plate installed, which “feels” great. The constant cel “sucks”. I have been "surfing" sites for days now, and I can find lots of information right up until I have generated a cel .....so my questions would be:
- Does the increased “boost” at “all times” caused by my egr delete, cause any concerns with normal day to day driving?
- If not, what is the easiest way to not show a cel? (other than black tape over the light, LOL). I do not have a VAGCOM but am willing to purchase.
- Do you know of any source (online) that could show me an “overview” of the egr system so I can determine what the engineers are trying to accomplish and how they are monitering the system so I can figure out how to "fool" it.
- Does my ecm need to be “adjusted” or “tuned” to accept "or be fooled into accepting" the egr delete I have installed and if so, any suggestions on who or where? Is this “tune” doable with VAGCOM.
