joloke
- Joined
- Apr 19, 2014
- Location
- Wiltshire United Kingdom
- TDI
- 2013 VW Golf 2.0 TDI + 1994 VW Caravelle 2.4 DI
I have a 1994 VW Caravelle I think you guys will know this as the Eurovan?
It has a 2.4d non turbo AAB code 5 pot diesel motor and a 4 speed 01m 098 CFZ code transmission.
Its been off the road now for nearly 2 months after transmission failure resulting in the Differential failing
Just prior to this it was starting to over rev in 3rd and change up to 4th harsh with a bump
When it failed we had to be recovered to our local garage we have used for years but they don't do trannys so contracted out the job.
Once the trans had a full rebuild the trans shop told us they still wanted full payment but it still jumped 3rd -4th.
We said we wouldn't pay unless they fixed it properly so then they started guessing saying it was the TPS and replaced it at their cost.
we now have it back but they lied they said the TPS fixed it but its still harsh 3rd-4th revving up to 3500rpm sometimes in 3rd
The famous ev6 has been replaced (or so they say)
We just want this right but they are saying its an electrical problem and the trans ran OK on the bench?
We have the Van back as we don't think we would of ever saw it again if we hadn't payed them but its cost us $3000 just to get it back with the same 3rd-4th problem
Any thoughts or advice?
Hopefully low cost as we cant afford much more as this unsuccessful rebuild has wiped us out
Jodie
Jodie
