Mark Hubley
I put my 2015 Jetta TDI on my lift yesterday, just to take a look. After removing the undertray (3 larger torx screws, and I think it was 9 smaller ones), I quickly found the location of the oil filter. Not as bad as what it looks like in a video I have seen of the Golf.
http://academic.pgcc.edu/~mhubley/Porsche/filter1.JPG
In this image, the front of the car is toward the top. There is minor obstruction by one wiring harness, but I don't think it will be a problem. The wiring harness can be moved a bit by unclipping from a support.
http://academic.pgcc.edu/~mhubley/Porsche/filter2.JPG
(The Insert Image function isn't working for me for some reason, so I'm just inserting links.)
Life is good when you have a two-post lift in the garage, but I think a DIY oil change will be fine on ramps or jack stands. Not as easy as on the '08 Lancer I just sold (super convenient location of the oil filter under the front of the motor). Looks like it will be a lot better than an oil change on my wife's '03 Tacoma (good thing I have long, skinny arms to get to that filter).
http://academic.pgcc.edu/~mhubley/Porsche/jettalift.JPG
With not-quite-900 miles on the car, I'm a ways away from my first oil change. If nobody beats me to it, I'll post a how-to when the time comes.
Looks like the filter housing does have the center drain plug. If anyone can figure out whether you just remove that and it drains, or if you have to screw something into it, please post that information. I've seen various tools supposedly for draining oil from these filters (http://www.metalnerd.com/cat17.htm), and I guess minimizing spillage.
