Bumping eng for cam photos
kitesurf
FL
Jetta 06
What is the best way to bump the eng and not have it start so I can rotate the cam for better pictures? thx
Ol'Rattler
PNA
2006 BRM Jetta
12 point socket on the crank shaft........................ only turn the crank clockwise.
2footbraker
Ontario, Canada
06 Jetta, 01 Golf
Easiest way is to just pull the big plug on the driver side of the cylinder head. The will prevent the injectors from opening.
Then you can just turn the key to turn the engine over a bit a a time.
Mach1
Vendor , w/Business number
Spicewood, Tx.
05.5 Jetta 5 spd, 06 Jetta DE DSG, 04 F250 6L, 2000 F250 7.3L
Or you can turn it from the cam..18mm. or from the acc belt..
Or already stated, from the wheel, or the crank
Ol'Rattler
PNA
2006 BRM Jetta
Make sure you don't turn the engine backwards. you could jump timing. Turning from the cam probably should be avoided as well. Might damage the timing belt.
