Old June 10th, 2009, 10:35   #1
c5ho
TDI(s): none
Default MK3 AHU TDI to MK3 Cabrio swap - whats needed?
I'm looking to swap a AHU TDI into a MK3 Cabrio.
I've found a 1998 TDI donor with about 250K kms and now I'm looking for a 'rust-free' MK3 Cabrio.
Is the swap pretty straight forward? This will be my first attempt at a swap although I currently drive a 16V MK1 Cabriolet (swap done by PO). What are the things that need to be swapped? I can think of:
-engine
-drivetrain
-pedal cluster
-gas tank?
-exhaust?
-fuel return line?
Any help/pointers are greatly appreciated! Thanks!
c5ho is offline   Reply With Quote
Old June 10th, 2009, 17:24   #2
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
PMed, and follow my A3-A3 thread as my swap progresses and/or stagnates.
Svante Arrhenius 1896
Old June 10th, 2009, 20:52   #3
tongboy
tongboy's Avatar
Fuel Economy: great and surprisingly not bad, depending on which car
100% plug and play on all parts, if the part is different on the cabroi put the tdi part on it, easy as that
4 door Rabbit TDI Swap
has been pulled apart and is now a
mk2 big turbo TDI swap 15.2 @ 101 3.2 60' - rearended - buy the parts car!
The faster car: 97 M3 with an all aluminum american V8 12.6 @ 116 2.0 60'
tongboy is offline   Reply With Quote
Page generated in 0.06977 seconds with 10 queries
[Output: 54.17 Kb. compressed to 48.83 Kb. by saving 5.34 Kb. (9.86%)]
